Truggy Buggy Hot Rod
Postby T-Rod-Buggy » 25 Sat Jun, 2011 8:53 pm
My Current project, its gonna be a "Hot Rod Buggy"
Complete transaxle rebuild and disc brakes added.
Rolling pan after all new balljoints and narrowed adjustable beam was installed.
Body on rolling pan
T-Rod-Buggy
Re: Truggy Buggy Hot Rod
Postby T-Rod-Buggy » 25 Sat Jun, 2011 9:01 pm
A few more pics.
Shroud and Feuling center mount oil filler.
Shroud and centermount oil filler.GIF (130.41 KiB) Viewed 10791 times
Fresh Build 1600, 110 cam, 1:25 rockers on solid shafts, C-moly pushrods, will ad a centermount fan/alt and a new set of dual Kadrons.
Fresh Build.GIF (113.83 KiB) Viewed 10791 times
T-Rod-Buggy
Postby BrianB » 27 Mon Jun, 2011 11:43 am
Good looking ride Roland. Are you going to have it ready for the Round Up Labor Day weekend? See ya there
Postby T-Rod-Buggy » 27 Mon Jun, 2011 6:33 pm
Im trying to . I keep losing garage time. If was on schedule, it would have been done in time for the June Bug Rally.
T-Rod-Buggy
Postby T-Rod-Buggy » 03 Sun Jul, 2011 9:24 pm
Little more progress, Cleaned up an old t shifter.
Trimmed up the engine tin, painted it, installed the oil adapter, put the shroud on and test fitted everthing together.
Mounted the carbs to see what it would look like. i will have to do some fabricating to get the linkage to work.
Re-freshed Shifter was black and ugly.
T-Rod-Buggy
Re: Truggy Buggy Hot Rod More Progress
Postby T-Rod-Buggy » 10 Sun Jul, 2011 5:24 pm
Some progress pics on the motor part of the build.
Fabricated/Modified the stock linkage that came with the new kadrons. Disassembled an ALT to blast the housing and re-surface the commutator and brushes. Fabricated an Oil filler cap out of scrap metal for the Feuling oil filler neck. Bolted up this exhaust so Id have something on it when I get ready to fore it up next weeked. Id like to trade out this exhaust for some megaphone exhaust that is wide enough to run dual carbs.
Feuling Oil Filler.GIF (117.23 KiB) Viewed 10680 times
Filler Cap.GIF (127.66 KiB) Viewed 10680 times
Fabbed Linkage.GIF (129.31 KiB) Viewed 10680 times
T-Rod-Buggy
Re: Truggy Buggy Hot Rod moe picturess
Postby T-Rod-Buggy » 10 Sun Jul, 2011 5:26 pm
Few more pictures of the motor
full View.GIF (89.62 KiB) Viewed 10680 times
T-Rod-Buggy
Postby T-Rod-Buggy » 16 Sat Jul, 2011 8:53 pm
http://www.youtube.com/watch?v=QW00fs5772k
Video of the first start up. I used basic ignition for the initial start up, tune and break in, but before it goes in the buggy I will install an MSD Dizzy, MSD wires, MSD Blaster Coil and an MSD6AL ignition box.
T-Rod-Buggy
Postby Jack Duncan » 17 Sun Jul, 2011 11:44 am
Good choice! That's what I have on my 1915cc and it never misses a beat. :)
Postby T-Rod-Buggy » 02 Tue Aug, 2011 8:29 pm
Did some plumbing for the gas lines.
Top View
Right Carb
Left Carb
T-Rod-Buggy
Postby T-Rod-Buggy » 02 Tue Aug, 2011 8:31 pm
one more picture
Pressure Valve
T-Rod-Buggy
