Muffler Rev. 3
Muffler Rev. 3
Postby staggerwing » 05 Sat Jul, 2014 1:23 pm
http://s68.photobucket.com/user/staggerwing6/library/MufflerRev3?sort=3&page=1
Special thanks the Dr. Michael Murzi for this idea. The Rev. 3 exhaust system is stealthy and peppy!
Re: Muffler Rev. 3
Postby GregR » 05 Sat Jul, 2014 1:57 pm
Yup, the hayabusa has a nice sound. Murzi helped me with my set up too.
I switch between the original quiet pack, haybusa and a stinger. Really like the hayabusa.
Re: Muffler Rev. 3
Postby MURZ » 09 Wed Jul, 2014 10:26 pm
You know if you want a little more sound you can remove the end plate and drill a few more holes to relive some back pressure. I like the modular design like Greg mentioned as well as you can switch just the muffler in 10 minutes.
Re: Muffler Rev. 3
Postby johber41 » 10 Thu Jul, 2014 1:11 am
Did the advanced style of muffler improve on your horsepower? Just curious...it has a great look to it. I have been told that the horsepower can be improved with a little more back pressure than my straight pipes allow.
Re: Muffler Rev. 3
Postby staggerwing » 10 Thu Jul, 2014 8:23 am
Yes.
Had duals before; first a Tri Mill dual bazooka system (which was pretty good, power-wise) then another dual set up with some Harley Davison mufflers tyhat someone (a biker) gave me. The second setup was a power-robber, but I think it looked okay. The current setup uses a baja header and a curved crossover pipe to the muffler. The power is back, and maybe a little better than with the Tri Mill system; and it's really quiet! The fit between the J-tubes and the header was poor (EMPI?). I ended up adding and inch or so to each J-tube so they fit was more positive (tube slid up in to header more), and also had to bend the drivers side of the header out a bit where the J-tube slides in to it so the piloting of the fit was more in alignment. It's a little ugly but that's just cosmetic stuff and can be remedied later. I like the performance and the sound much better than the last two systems!
Re: Muffler Rev. 3
Postby GregR » 10 Thu Jul, 2014 10:04 pm
Just wondering if you have any support for the muffler other than the crossover pipe?
Re: Muffler Rev. 3
Postby staggerwing » 11 Fri Jul, 2014 8:13 am
The muffler has a factory-welded aluminum bracket on it that's facing down and out of sight when viewing it from the rear of the buggy. From that bracket, there's a 1" wide x 1/8" thick length of mild steel about 3" long that's welded to a piece of 1.5" tubing that was cut in half horizontally, so it would rest on the header pipe. That half-moon piece is welded to the header pipe and a 1/4" bolt holds that brace and the muffler bracket together. I'll post a picture when I get home this evening. It's a pretty rigid setup. I think the whole thing is going to get heat wrapped.
Re: Muffler Rev. 3
Postby staggerwing » 12 Sat Jul, 2014 8:05 pm
Like so:
Re: Muffler Rev. 3
Postby johber41 » 14 Mon Jul, 2014 6:55 pm
Nice fabrication with the mounting bracket!
Re: Muffler Rev. 3
Postby Ken » 15 Tue Jul, 2014 9:17 am
That old man's wife does some nice fab work. Great job Sandy.
Users browsing this forum: No registered users and 45 guests
