I had the pleasure of spending a couple of hours with Doug at Qualitat this past Saturday. You see, I was having a heck of a time getting my Kadrons adjusted right. I had considered going elsewhere before I thought of Qualitat. When I called Doug at Qualitat he said to bring it on in. After doug tried to adjust the Kads without luck. We had to let the engine cool down to re-adjust the valves and check compression. To make a long story short, Doug found a problem with the bad carb, fixed it and I was back on the road.
This was the first time that I had used Doug at Qualitat. He has been at the same location since the early 70's. Qualitat is also an Empi distributer and his prices are very reasonable. We are very lucky to have such a skilled and knowledgeable sponser of our club.
I would highly recomend qualitat. Stop by and say "HI" and meet Doug. You never know when your goni to need him.
