Pulled Threads
Pulled Threads
Postby S/C4095 » 06 Thu Nov, 2008 9:40 pm
Went to put in my oil pressure sending unit and I could screw it in quite easily. When I tightened it it must have pulled the threads in the engine. I can still screw it in but it seams to bottom out on the large part of the sending unit. You can see the worn threads in the case. Any Ideas
S/C4095
Postby Greaph » 07 Fri Nov, 2008 10:32 pm
Helicoil?
Not sure if it's still made (likely so), but I've used them many times on stripped/damaged threads on engines.
Should be able to find it at any auto parts store.
This IS my sig......
Greaph
Postby David O' » 09 Sun Nov, 2008 7:51 pm
No, on the heli coil.....those are pipe threads! If you get a 1/8 pipe thread fitting, (short copper tube) you can put another double female fitting on that and screw the oil pressure switch on to that.
