So...
So...
Postby CoryN » 24 Thu Dec, 2009 9:18 am
We hopped in the buggy last night to go look at Christmas lights, as it was still quite warm here last night.
As we are going I'm noticing the headlights starting to dim, soon the blinkers quit working, then it started to miss a little, so I'm hauling butt for home and about six blocks out it dies all together.
I'm assuming I ran the battery dead with the headlights running and eventually didn't have enough juice for spark. I didn't think the generator was working right, but the meter was looking like it was.
Time for an alternator I guess.
Postby Ken » 24 Thu Dec, 2009 2:10 pm
Sounds like you need to polarize your generator...
Is my generator charging?
If you have a voltmeter:
* Measure the voltage across the battery. Should be around 12.6 volts with the engine off. As the engine speeds up, the voltage should increase to somewhere around 14 volts. If it does, the generator is working and charging the battery.
* Check brushes are not worn excessively. If you can, apply a little pressure to the brushes while the engine is running and see if the gen light goes out or the voltmeter reading increases.
If you do not have a voltmeter:
* Get the car started, even by jumping if required.
* Remove the + cable at the battery
* The car should remain running. If it dies your generator is not charging.
* It the car remains running, begin increasing the electrical load. Turn on lights, radio, everything that will increase your electrical load.
* If at any time your car struggles to stay running, you are not producing enough power for your cars demand.
Replace brushes if required.
Generator Testing
* Disconnect the generator from the regulator (probably easiest to simply take the wires off the generator).
* Connect a jumper from DF on the generator to the generator frame. Now run the engine and measure the voltage from ground to D+ on the generator.
NOTE: Some generators have different types of terminals; verify which is DF and which is D+.
* As you increase the engine speed, the voltage should jump up to +35 volts or so (@3000 RPM).
If it passes this test, the generator is good. Don't run this test longer than necessary as it will overheat the generator.
If it fails this test, the generator may be good but need to be polarized. Check out "How To Polarize Your Generator".
NOTE: These tests are for 12V generators. The same tests will work on 6V generators but the voltages will be roughly one half the 12V values.
Second, a little bit about polarizing
Why do generators need to be polarized? Generators need some magnetism to get started. This "residual" magnetism remains in the field pole pieces even after the engine has stopped. The next time the generator starts up, the residual magnetism creates a small voltage in the Armature windings. Not enough to charge the battery, but enough to allow the field windings to draw current. As the field current increases, the pole pieces create even more magnetism. That makes even more voltage in the armature, and the cycle continues until the generator is capable of producing maximum output.
Anytime a generator is disconnected from the system, there is a possibility the residual magnetism may have decreased to the point where it can no longer get the generator started producing voltage. In the case of a new generator or one which has been mis-treated, the residual may even be of the wrong direction (north and south poles reversed).
Polarization is a simple process used to restore the field pole residual magnetism and ensure the magnetic direction is correct.
Now, How to Polarize Your Generator
* Remove the fan belt.
* Connect a jumper wire from DF to ground.
* Connect a wire from the battery + terminal to D+ on the generator.
* The generator shaft should start to spin.
* Don't run this way for more than a few seconds to avoid overheating.
* If the generator did not spin, the generator is likely defective.
* The generator will now be properly polarized.
* If it did, put the belt back on and re-test for generator voltage with DF grounded. If the output voltage is still low, the generator is defective.
Do regulators need to be polarized?
No, regulators are not polarity-sensitive. The instructions supplied with some voltage regulators, actually polarize the generator, not the regulator.
Postby jspbtown » 25 Fri Dec, 2009 1:17 pm
I say go for the Alternator!
Chrome kits are about $160 with free shipping. I just bought one for my project which I won't be touching until a late next year. Good deal so I couldn't pass it up.
Postby CoryN » 25 Fri Dec, 2009 1:36 pm
Chrome is what I was planning to go with the new billet stand and serpentine belt system. Where did you see the good deal?
Postby Don » 25 Fri Dec, 2009 10:38 pm
I dream of a chrome alternator...and fuel pump.
Postby CoryN » 26 Sat Dec, 2009 9:29 am
I'm thinking billet fuel pump block off plate and hidden electric fuel pump
Postby jspbtown » 26 Sat Dec, 2009 10:56 am
Kustom1warehouse has them for $161 including shipping, but CIP1 has them for $159.95 including shipping and they come with the pulley shims where the Kustom1 one do not.
These do not include chrome alternators..just the pulley, backing plates, stand, and strap.
The chrome alternator is usually about $30 more at CIP1. You can buff up the stock one VERY easily. In this picture all I did was take some sandpaper to a used alternator to clean it up. It took maybe 20 minutes? With the one I just got I am going to go sandpaper, some polishing pads, and then use a little buffing kit from Harbor Freight. It would look awesome.
Cory, with the level of detail you have you could easily make one look almost like chrome.
Some links for alternator kits:
http://www.kustom1warehouse.net/New_12_ ... 82xkit.htm
http://www2.cip1.com/ProductDetails.asp ... 10-5750-CH
Postby CoryN » 26 Sat Dec, 2009 12:40 pm
I have a billet stand and serentine belt system so all I need is the alternator. Are they aluminum? That might actually be better then to polish aluminum instead of going with the chrome
Postby Bryan Porter » 26 Sat Dec, 2009 12:56 pm
If you polish it you have to keep polishing it as it will get dull
crome it just keeps on shining just a little wax.
Postby jspbtown » 26 Sat Dec, 2009 1:47 pm
I am 99% sure they are aluminum. Definitely not a cast steel.
Postby Fred » 26 Sat Dec, 2009 6:12 pm
Yo Cory, I got an Alternator @ Auto zone for 50 bucks and It looks like aluminum. They took my generator for a core, PM Me for details if you choose this route. Fred
Fred
Users browsing this forum: No registered users and 21 guests
