Jack Duncan wrote:Yes, cut that mess off with a torch and put it back the way it's suppose to be. Bolts through the bracket is the smart way to mount the bumper. The front mount broke because of torque and twisting from braking and power on situations. After replacing the mount, install hold down straps across the top of the trans and on the rear of the engine. You can buy them in kit form with instructions. It should especially be on larger engines with a lot of torque. Don't mean to be a "Know it all" but I did my research and put the kit on mine.
ckolek wrote:running solid mounts on my buggy with little to no vibration issues at all.. remove the bolts and fix your car correctly after all its your life and other people on the road with you!!
