Check it out!
Check it out!
Postby Faron » 12 Sun Mar, 2006 11:11 pm
Look I have some real progress! Last time I showed photos, it was just a painted Chassis/Pans. If you see a mistake PLEASE let me know! Thats my wifes new car that I got a SCREAMING Deal on! (I sell MINI/BMW, and my buddy is the used Pre-Owned Manager. SCREAMING DEAL! Could NEVER of afforded it other wise!) 2005 BMW X3 She loves it!
Postby carlos del carpio » 13 Mon Mar, 2006 12:33 am
The pics are too tiny to view for errors, but nice bike
Hummm
Postby Faron » 13 Mon Mar, 2006 9:35 pm
:D I have larger photos! :D
Postby carlos del carpio » 13 Mon Mar, 2006 10:27 pm
hm,..can you take a pic of the top of the front shocks? thanks
Postby David O' » 13 Mon Mar, 2006 11:28 pm
Are you going to put the front sway bar on? If the shocks are gas shocks, you may find the ride to be rough!
Postby Faron » 14 Tue Mar, 2006 9:58 am
This is the top of the Shock Carlos, Thanks for taking a closer look!(If you left click on it it will enlarge.) I may of never said this, but I have always had the desire to build a car. But I am working with VERY limited knowledge. But I am not scared to ask for help! The fact that you are all so willing to help is awesome, Once again Thank you. (WOW!!! I guess I need to sand and paint!)
The front sway bar.......so I shouldn't put it on? Its the stock front end and I was planning on putting 15 by 6 wheels with nice street tires up front. I do want it to have as comfy a ride as I can get. Keep in mind I like the ride I get from a MINI or a BMW, but I think the soft ride of a Caddy is the worst. (Its worth it if you are talking about one of those cool looking Old Long Caddy's that are all Mob Style.)
I was planning to buy a spun alum. gas tank & put in the rear, because they look cool. (And I don't like the look of a gas cap in the middle of the hood for me. Its great for other people! Then I was thinking of securing some weights have that weight on the front end. But easy enough to remove if I want to.
Postby carlos del carpio » 14 Tue Mar, 2006 11:56 am
The bushings on the top of the front shock should not be the same diameter as the metal washers... loose it up a bit.... :lol:
Postby blackthree4me » 14 Tue Mar, 2006 1:36 pm
I have the same set up as you with built in adjusters cranked all the way back up so I dont rub the fenders. still do but only with passengers.
I also have the larger 3/4" sway bar and have not felt it to be too rough if anything its a little soft for me under braking.
youll be fine if you like the minni s ride.
also on the shock bushing they are side spicific, one has a larger rubber step that one goes on the bottom to fill the hole in the beam tower
