Afraid to say it.. I've tried without the wipers. Doesn't pass.
I've taken Vdubs into get them inspected without the washer fluid and told the inspector due to this I'd really like for you to pull the wiper blade away from the window and turn it on so you can see that it works.
After you get it inspected you can take it off. I've passed with one blade on my buggy before. It swiped the whole window when it was on.
Reason why I tell the inspectors to pull the blade away is due to most of us don't have wiper fluid. If they turn it on and you have a bad balde 9 times out of 10 your blade will scratch your glass. Then you have to stare thru a half circle scratch to drive and later be out of some money to replace your glass.
I tell them if you don't pull the blade out to check it to see if it moves or not and you do it on my window and it scratches they are paying for the glass and kit to replace it. They always pull the blade away from the window and turn it on to see if it works.
There is a kit some place that shows you how to install a wiper that works. After the inspection you just take it off till the next inspection. It will only work on your buggies not a Manxter.
