What is necessary to install this type filtration
Postby DannyT » 11 Wed Mar, 2009 7:09 pm
DannyT
Postby David O' » 11 Wed Mar, 2009 10:09 pm
It is a bolt on unit....if you have the oil pump that goes with it and it is the right one for the engine that you have.
Postby DannyT » 11 Wed Mar, 2009 10:23 pm
I have seen where it ask for either a flat or dished cam.....I guess the only way to find out is to pull the pump. I dont think I can use it on my rail due to interference from a cage tube but was thinking of using it on my wifes buggy.
DannyT
