Wheel adapters
Wheel adapters
Postby Aquabuggy » 03 Fri Feb, 2006 6:25 pm
What do you all think about wheel adapters?
Ive got them on my aqua buggy with no problems, But I will be running much bigger tires on the new buggy I'm building.
Anyone ever have trouble with them?
Postby David O' » 03 Fri Feb, 2006 6:42 pm
If they are steel and they are the thick steel adapters, ( not the stamped cup type) there should not be a problem!
Postby Aquabuggy » 03 Fri Feb, 2006 6:52 pm
They would be type that go VW 4 lug to chevy 5 lug. I think the ones on my aqua buggy are aluminum. Do these also come made of steel?
Postby bobaganoosh » 03 Fri Feb, 2006 8:06 pm
I have a set of those in my garage.
I may use them on another project, but for now they are collecting dust.
mike
bobaganoosh
Postby carlos del carpio » 03 Fri Feb, 2006 8:39 pm
I got some wide 5's to Chevy's if you want them...
Postby GregR » 03 Fri Feb, 2006 9:24 pm
I think on a street buggy they're not much of an issue. But on a buggy that may be off road and get bounced around pretty hard I don't know how much I'd trust them. If you go discs get blank rotors and drill them for Chevy...just a thought.
Postby Aquabuggy » 03 Fri Feb, 2006 9:35 pm
Hey Greg,
How did your new disk break install go?
Can ya tell much difference in stopping power or over all handling?
Postby David O' » 03 Fri Feb, 2006 10:40 pm
Greg is right! But also, the ones you are talking about are fine! My two cents worth!
