by jspbtown » 03 Tue Nov, 2009 1:26 pm
I "think" the 1967 was the first year for the 12 volt. If so, it should have the 200mm flywheel and will bolt right up with no problems. If it was the 6 volt you just need some clearancing which is easy.
I also suggest a started from an autostick. Much better option.
