HELP!
HELP!
Postby jordanj » 23 Mon Nov, 2009 8:23 pm
I need help,im trying to adjust my valves but once i get to cylinder 4 and try to adjust it the springs just keep coming out.like i can take the whole adjustment knob off and there is zero play in between the rocker and valve.What could my problem be?
jordanj
Postby Aquabuggy » 23 Mon Nov, 2009 9:46 pm
Any chance your missing the valve locks on that valve?
http://www.pacificcustoms.com/AC109470.html
Postby jordanj » 23 Mon Nov, 2009 10:02 pm
Are those at the top of the valves?also i just found out that its that whole side.i took off the rocker arms and i didnt see anything weird or wrong.I even switched the rocker arms around and get the same outcome.These are the stock 1600 rocker arms im using.
jordanj
Postby Bryan Porter » 24 Tue Nov, 2009 9:36 am
Push rods to short , valves broken or too long
Did you change the cam you might need a shim under the rocker stand if you did.
If you have swivel feet adjusters you might need a shim also.
Postby jordanj » 24 Tue Nov, 2009 12:16 pm
yea i did change the cam to a weber 110.idk how the pushrods would be too short sonce cylinder 1 and 2 head adjust fine.And this is a stock vw head that way cut for 90.5 pistons.So wold i just put a shim under the part where the rocker bolts to the head?
jordanj
Postby jordanj » 25 Wed Nov, 2009 12:38 pm
anybody got anything else?
jordanj
Postby Aquabuggy » 25 Wed Nov, 2009 2:52 pm
Jordan, I think Bryan has pointed you in the rite direction (broken or stretched valve stem) most likely.
You could also try posting this question on the samba you will be reaching a much larger audience.
http://www.thesamba.com/vw/forum/viewforum.php?f=12
Postby jordanj » 25 Wed Nov, 2009 5:07 pm
how hard is it to fix a streched valve stem?
jordanj
Postby jspbtown » 25 Wed Nov, 2009 6:00 pm
Before you start tearing into it I would take some measurements. Remove the rocker arms and measure the overall spring height on the ones that adjust correctly and the one that is not right. Compare those measurements.
Are they all the same?
No, the one that is out of whack is taller:
Then your stem may be stretched or you may have lost a valve seat. Either way the head needs to come off.
Yes they are the same height:
Then compare your pushrods. All the same length? If so then maybe you have a lifter hung up in a bore. Slide a pushrod into the lifter and turn the motor over while applying pressure to the pushrod. Does it go in and out? If not, then your lifter is hung up. You can try to rotate the crankshaft so that cylinder is at TDC and try to gently tap the lifter back down with an old pushrod and a hammer. Be careful! You may need to split the case to get at the lifter if you cannot free it.
