Sidepod Intallation
Sidepod Intallation
Postby Patrick » 04 Thu Mar, 2010 10:17 pm
DELETE
Patrick
Postby BrianB » 05 Fri Mar, 2010 8:21 am
The only way I could find was to bolt on either end of the pod. I had to add to the pods to make it happen as you can see in my build thread. I think next time i will mold the pods to the body on the ends but not along the body sides. Is the this for the Manxster? I would have thought they would have done something to make this easier to do.
Postby Bryan Porter » 06 Sat Mar, 2010 9:32 am
I also bolted them front and rear four 1/4 inch bolts worked like a charm
Postby Jack Duncan » 07 Sun Mar, 2010 7:34 pm
Mine has two bolts in front and two in the rear with one on the bottom through the pan side flanges. That being said, you have to have plenty of patience to get all the holes lined up, It also takes two people since your arms probably aren't long enough to reach inside and outside at the same time. :)
