Alternator mystery
Alternator mystery
Postby Fred » 18 Tue May, 2010 8:06 pm
When I start the car the alt light comes on until I rev the engine pretty good(3000 RPM) and then it goes out. After running for a while it comes back on and only dims a little when revved. Could this be because I have a new battery and it doesnt need to charge or do y'all think there's a problem? when I disconnect the Positive terminal on the battery the car dies, All these Parts are new, any ideas?
Fred
Re: Alternator mystery
Postby jspbtown » 19 Wed May, 2010 8:08 am
I would check your connections and belt tension.
You say a new battery.....I assume the old one died? Whats the voltage read when the light comes on? You can check it with a voltmeter. Your alternator could be on its last legs.
Postby Ken » 19 Wed May, 2010 9:24 am
Fred wrote: when I disconnect the Positive terminal on the battery the car dies, All these Parts are new, any ideas?
It could be a connection, but it sounds like the alternator is not functioning properly. I would pull it and have it tested. If the system is connected properly (it was not doing this before?) you simple test is a pretty sure indicator of a bad alternator. Your battery is likely providing all of your electrical needs and is not being recharged. Starting problem are sure to follow...
Postby Don » 19 Wed May, 2010 1:15 pm
jspbtown wrote:I would check your connections and belt tension.
Definitely check belt tension and condition. Might want to pull your alternator pulley and make sure there is a woodruff key.
Postby Fred » 19 Wed May, 2010 9:16 pm
Its amazing how something so out in front(Rear) and accessable can be such a pain in the a#% to remove!! :? The alternator is under warranty so I just pulled it and will replace it tomorrow. Thanks for all the help, Fred.
Fred
