Drain Plug
Drain Plug
Postby Ken » 25 Wed Apr, 2012 2:50 pm
Is there something better?
I use one with the magnet and has a flat rubber seal.
My concern is that the rubber seal doesn't allow much torque.
I drained my oil last night and I could almost have taken the plug off by hand.
Got me worrying about it loosening up on the road.
Re: Drain Plug
Postby Bryan Porter » 25 Wed Apr, 2012 3:12 pm
use the copper one that comes with the gasket set.
Re: Drain Plug
Postby Jack Duncan » 25 Wed Apr, 2012 8:02 pm
Being a retired jet engine technician, my first thought was to drill a hole through the head and safety wire after it is torqued down.
Re: Drain Plug
Postby Ken » 26 Thu Apr, 2012 8:49 am
Bryan Porter wrote:use the copper one that comes with the gasket set.
I don't find a copper plug with a gasket.
My issue is the o-ring seal. I think a rubber seal will always allow loosening overtime.
Maybe I just need to replace the o-ring seal I have now with a nylon or copper washer/seal?
Jack Duncan wrote:Being a retired jet engine technician, my first thought was to drill a hole through the head and safety wire after it is torqued down.
Is this what you have Jack? You got a picture? I'd like to see what you wired it to, to keep it from loosening.
Re: Drain Plug
Postby Jack Duncan » 26 Thu Apr, 2012 11:14 am
I don't have a safety wire (yet), but it seems like a good idea. I just looked at mine and the flange of the cover plate extends down far enough to drill a hole in it too. It's 2" away and can be drilled in a position to prevent the drain plug from turning. Just be sure to deburr the holes to keep from cutting the safety wire. I'm going to change my oil today (my first oil change since the engine was built. 600 miles!). I may safety wire the plug as I mentioned, then take pictures. :idea:
Re: Drain Plug
Postby Jack Duncan » 26 Thu Apr, 2012 11:16 am
I'll post pictures as soon as I clean the bug spray off of my computer.
Re: Drain Plug
Postby ckolek » 26 Thu Apr, 2012 4:38 pm
thats funny Jack, i was just trying to squish the bug myself!!!!
