I want to hook up the turn signal indicator on my buggy, but I don't know where to connect the wire coming from the little light bulb in the speedometer to.
It has a two tab flasher. If I connect it to one of those tabs, then the green bulb is on solid all the time, until I turn, then it blinks, after the turn, it goes back to steady on.
Do I need a three tab flasher? Any suggestions?
Robert
