crank oil leak
crank oil leak
Postby Bryan Porter » 06 Mon May, 2013 5:47 pm
Dave it's not the screen!!!!!
Check the oil level and check for blow by.
Re: crank oil leak
Postby Dave W » 06 Mon May, 2013 10:41 pm
Hi Bryan,
Thanks for the input. I think the oil level is OK. When changing the oil, I have always used 2.5 quarts of 20W50. I did not think the screen would be the problem, but along with the oil, this is the only item changed since Fredericksburg.
With my current engine set up, I do not believe there is any crankcase ventilation (no tube running from oil fill tube to air cleaner / no breather box system installed). Could this be contributing to the issue? This is how I ran in Fredericksburg with no oil throw issue.
I received the MST sand seal adapter and will proceed to install the sand seal pulley this week to see how this performs. Would still like to better understand why I had so much oil throw on Saturday with the standard pulley set up and what can be done to correct. It sure made a mess of the engine. Appreciate any further input you have.
Thanks so much!
Dave
Re: crank oil leak
Postby Bryan Porter » 07 Tue May, 2013 8:52 am
You need the tube from the filler to air cleaner this will let any crankcase pressure out the breather not the pulley.
