look what I did today again
Postby bobaganoosh » 27 Sat May, 2006 5:05 pm
not for the second time, just the second time I have used this subject.
stainless steel is a booger to cut, but I did it with four metal jigsaw blades and two drill bits.
I know the holes are a little rough but when the guages went in and the switches are on you can't even see it.
mike
bobaganoosh
Postby bobaganoosh » 27 Sat May, 2006 5:06 pm
and wait till you see it on the dash board, I'll have pics of that in a little while.
mike
bobaganoosh
Postby bobaganoosh » 27 Sat May, 2006 6:32 pm
and tadaaaaaaaaaaaaaaaaaaa!!!!!
and this is where a glove box used to be but was an aweful hole and I didn't really want a glovebox anyway I mean I don't even drive with gloves on.
hope you likey
mike
bobaganoosh
Postby GregR » 27 Sat May, 2006 7:43 pm
Nice job.... :D
Postby carlos del carpio » 28 Sun May, 2006 2:26 am
I guess I have it easy, I just need to cut thru fiberglass..though the fiberglass splinters really are horrible!!!
A tip to those are cutting thru fiberglass or steel with a hole saw, clamp a piece of wood behind your area..it'll keep the bit straight, won't let it wander..
Postby bobaganoosh » 28 Sun May, 2006 9:25 am
all this stainless is covering fiberglass.
the guages that were in there I didn't like so I got different ones and they don't fit the same holes so I cut the stainless piece so I could use the guages that I want. the speedo was smaller the the original and the fuel guage was bigger plus if you notice there's no place for a key.
mike
bobaganoosh
Users browsing this forum: No registered users and 59 guests
