tubing tubing tubing
Postby carlos del carpio » 30 Fri Jun, 2006 3:24 pm
Alrighty folks! The carpet and padding is IN! YAY! Now, the bad news..
I realized I'm supposed to run stuff under there..what is it? Accel. cable, clutch cable, and parking brake cable? I guess the brake lines are optional...
I guess I can run the tubing.. TUBING, to enclose the cables...... what size tubing did you run and where can I get some??? THANKS DUUUUUUUDES!
Postby bobaganoosh » 30 Fri Jun, 2006 7:58 pm
are you running your accel cable through the stock tube or a new cable in a new location
also the stock ebrake should have some tubing run through the tunnel as well all you should need to do is fish a brake line under the carpet
I ran all new lines and used the vinyl tubing that came with the off road vinyl brake line kit for a sheath for the throttle cable.
mike
It aint for show, but it sho will go.
bobaganoosh
Postby carlos del carpio » 30 Fri Jun, 2006 9:19 pm
It's gotta be new tubing, I'm not using a stock VW frame... I'm spending the day (and tons of bling bling in fuel) looking for 1/4 and 3/8 ID tubing, metal... :(
Postby Aquabuggy » 30 Fri Jun, 2006 9:32 pm
Carlos,
I got my tubing from home depot 1/2" I thank. Just take you e-brake cable and find tubing that fits snugly over the cable end.
Postby carlos del carpio » 01 Sat Jul, 2006 12:04 am
I tried home depot, they have the tubing, but up to 3 feet.. I need a looong one for the accel cable and clutch cable :( I'll try a steel store, if they're open tomorrow...
Postby David O' » 01 Sat Jul, 2006 12:58 am
12mm O.D. hydraulic tubing make s a great replacment tubing for the e-brake and the clutch tubing. Get it in the 1.5 mm wall thickness.
Postby Aquabuggy » 01 Sat Jul, 2006 7:14 am
Two 4 foot sticks was all i needed. Cut one in half use it for e-brake and use the other full stick for clutch cable. I used a smaller tube for the accel cable, got it at autozone fuel line or brake line cant remember. You could also use one of the plastic accelerator cable/tube kits.
http://www.mooreparts.com/mm5/merchant.mvc?Screen=PROD&Store_Code=MP&Product_Code=AC720001&Category_Code=AACCEES
Postby David Head » 01 Sat Jul, 2006 10:37 am
For accelerator cable. is used spare brake line tubing. For clutch, I used 1/2 metal conduit
Postby carlos del carpio » 01 Sat Jul, 2006 12:53 pm
HEYYYYYYYYYYYYY! Over sized solid fuel line! It's sturdy,cheap, readily available, and I can easily BEND IT! YOU DA MAN!
and thanks guys! Time to get to worky work!
