urethane
urethane
Postby mufasa » 05 Mon Feb, 2007 2:53 pm
I will be rebuilding my suspension soon and wondered what your thoughts on urethane is. I have read that they are quite noise and that they bind up the suspension. Your experiances and recommandations? thanks Mufasa
Mufasa Proud to be a Viet Nam Veteran.
mufasa
Postby David Head » 05 Mon Feb, 2007 4:54 pm
I've had them on both of my buggies, I guess they squeak if you push up and down on the suspension while the engine is not running. But I don't hear them when I'm driving.
I say go for it.
Postby David O' » 06 Tue Feb, 2007 12:57 am
If you lube them with silicone, they won't bind and they tend to be quiet.
I hope this helps!
Postby Mike & Mel » 16 Fri Feb, 2007 11:51 am
Stick with all HD rubber mounts and gromets, specially if you run it hard, or go off-road at all. The poly will squeek, and eventually the bolts will pull through, as the poly tends to deform and flow under pressure.
Mike & Mel
Manx Club #2265
RBC - THE Place to Be. www.RBCdunebuggy.org
Texas Manx Club
One of T.O.P.s
Joe Poty Sand Rover
Mike & Mel
