Small Batteries
Small Batteries
Postby MURZ » 01 Tue Jan, 2008 1:08 pm
Guys here is some info on small sealed batteries. I would use the ETX 30L group size. If you can't get a CARQUEST battery, try Oreily's they sell East Penn batteries as well...also sold as EPM brand. We are OE on every Harley manufactured. The ETX 30L is for the big Harleys and I have personally tested it to the 550-565 CCA range. Same exact size as an Oddesy PC925...only more powerful. Personally tested ;-)
Whatever you get, make sure it is a Sealed AGM design. If it comes with acid it isn't AGM. AGM, Absorbed Glass Mat. The acid on these batteries is injected under vacuum so that only a certain amount of acid goes in the battery. It is then sealed.
AGM batteries can be deep cycled, charge 50% faster than flooded wet cell bateries and are much more resistant to vibration.
Here is the link for more reading. Good Luck!!
http://www.thesamba.com/vw/forum/viewto ... ht=battery
Postby Aquabuggy » 01 Tue Jan, 2008 3:33 pm
Thanks, thats what I was looking for.
This looks perfect wonder what's holding up there.
Any idea if there is a comparable size in the East Penn or EPM brand?
Postby MURZ » 01 Tue Jan, 2008 4:28 pm
We don't make a battery close enough to fit that particular box. You could build a similar box with angle iron and bolt to the seat area using an ETX30L battery for much less $$$$.
Murz
Postby Texasbuggys » 01 Tue Jan, 2008 4:57 pm
Good info and something everyone has to decide. Do you have a price comparision between the odd 925 and the Penn of similar cranking amps?
Postby MURZ » 01 Tue Jan, 2008 5:05 pm
Prices will vary depending on price schedules of stores. I would just check around.
Ask for part number ETX30L and make sure it is an AGM design.
Postby Aquabuggy » 01 Tue Jan, 2008 7:33 pm
Think this one has enough CCA? its a little thinner then the etx30
http://www.batterymart.com/p-Big-Crank- ... ttery.html
Here's the full line of ETX
http://www.batterymart.com/merchant2/merchant.mvc?
and the Odyssey line
http://www.batterymart.com/c-odyssey-batteries.html[/img]
Postby MURZ » 01 Tue Jan, 2008 7:37 pm
ETX 18L will be fine.
Postby Aquabuggy » 01 Tue Jan, 2008 7:42 pm
Cool! and its half the price of Odyssey :D :D
Great info
Postby Texasbuggys » 01 Tue Jan, 2008 10:05 pm
Thanks Chris and Murzi, great topic and info!
