Progresive carb
Progresive carb
Postby KIM-P » 08 Fri Feb, 2008 8:00 pm
I just rebuilt my carb and it starts and idles fine, but bogs when I blip excelerator. It seems to have a sweet spot some where near half throtle, but falls on its nose as I excelerate past this point. There are no heat risers on the scat intake and the intake sweats just under the carb. This carb has the 5 bolt patern on the top cover where most other progresive carbs have the 6 bolt patern. Not sure what size engine other then dual port heads 1600 case and a nice lumpy cam (maybe a 110?). 009 distributor and dual exhaust. I'm thinking larger jets and maybe a larger squirter for the excelerator pump. Any of yall got any ideas or has any body came across anything like this before?
Progresive carb
Postby KIM-P » 10 Sun Feb, 2008 3:18 pm
OK I'll answer my own question. With no heat risers for the intake it takes about 15 minutes to warm up making it run much better ( more responsive ) past part throtle. I'm have opened up the squirter to the next size, (using a drill bit type torch tip cleaner),bottom end response is much better.
Postby jspbtown » 11 Mon Feb, 2008 12:37 pm
009 may cause a little issue as well.
progresive carb
Postby KIM-P » 11 Mon Feb, 2008 8:38 pm
Is there a fix for the 009 or should replace it with a better distributor?
Postby jspbtown » 11 Mon Feb, 2008 9:37 pm
Make sure it is timed correctly. I don 't have the exact numbers but I am thinking 28-32 degrees of total timing at 3500 rpm. Let me double check those numbers in the morning.
Other than that a good SVDA distributor is your best bet.
Postby jspbtown » 12 Tue Feb, 2008 11:05 am
Yup...
28-32 BTDC @ 3500rpm
Progresive carb
Postby KIM-P » 12 Tue Feb, 2008 8:34 pm
Thanks I'll check it out first chance I get. KIM-P.
Postby ckolek » 13 Wed Feb, 2008 8:35 am
hey Kim, are the pipes more quiet than the ones you have?
Postby KIM-P » 14 Thu Feb, 2008 8:42 pm
YOU BET THANKS. I HAD THE MACHINIST AT MY JOB CUT A WASHER TO FIT IN THE ONE PIPE THAT HAD THE PACKING COMING OUT AND THEN TACK WELDED IT IN PLACE. THE PIPES EVEN LOOK BETTER ON MY BUGGY THEN THE FOUR PIPES THAT WERE ON IT. KIM-P.
