Shifter
Shifter
Postby CoryN » 30 Wed Apr, 2008 7:27 pm
Going to stay with the stock shifter for now - trying to keep everything simple until its put back together, then I can go back and replace things with better later.
Any reason to select either of these over the other? I have my favorite in terms of looks, but any good reason other than that?
Postby Aquabuggy » 30 Wed Apr, 2008 8:27 pm
The one on the right side is an older style and the shift rod will have a groove that the pin goes into. I think the one on the left will work in ether old or later model shift rod.
The stock shifter is better! Most aftermarket shifters are junk unless you wanna spend the big bucks on a Berg shifter.
Postby CoryN » 30 Wed Apr, 2008 8:36 pm
Well the older style has a very pronounced pin, the newer has like a ball bearing similar to a ratchet for a socket. Both appear to fit in my shift tube.
I'm leaning towards the newer style, more because its shorter and in my opinion a little cleaner look.
Postby Greaph » 30 Wed Apr, 2008 9:38 pm
Meh, I like the lines of the older one better....
just my .02
This IS my sig......
Greaph
Postby jspbtown » 01 Thu May, 2008 11:11 am
Cory,
I know you said you want to keep it stock but in my opinion a new shifter is one of the few upgrades that are really worth it. Even the cheapest EMPI shifters at 450 or so are well worth it.
Jeff
Postby CoryN » 01 Thu May, 2008 11:53 am
Jeff - I'm hoping you mean the Empi's at $45.
Postby jspbtown » 01 Thu May, 2008 12:46 pm
Sorry,
My typing fingers are still in Mexico....the rest of me got back late last night.
$45.00 us dollars
Postby MURZ » 01 Thu May, 2008 11:17 pm
I like a stock shifter with a quick shift kit. I have never had any luck with the aftermarket stuff. Small detail....don't let it bug ya
Shifter
Postby the 'Maniac » 06 Tue May, 2008 10:45 am
Hey Cory... as others have posted, the newer straight shifter will work with all years of shift rods, but the older tapered & taller shifter has a pin that requires a matching shift rod with a slot in the shifter socket. The pin keeps the shifter from turning in its socket, since it is curved.
You can modify a newer shift rod & put a slot in it, to use with the older style shifter.
Since I re-built Xena 8 years ago, I've used an EMPI "short buggy style" shifter with the "T" handle & a reverse lockout button. It has always worked fairly well, but about a year ago the reverse lockout button wouldn't release the little pin & it would want to go into reverse, shifting from 1st to 2nd.
When I recently installed my new transaxle, I pulled the shifter to inspect it & the "lockout plate" was massively worn. I removed it & am very careful shifting now.
I think I'm going to go with a late model straight shifter with a "Quick Shift" as I did in previous VWs I've owned.
**NOTE** Most of the Quick Shift" kits made now are made of plastic, which do not last or work as well IMO.
I bought a couple of Quick Shifts recently & the parts guy found some of the metal ones in stock. I'm going to install one in our 71 VW Bus too.
Have FUN FUN FUN... the 'Maniac
the 'Maniac
Postby CoryN » 06 Tue May, 2008 11:02 am
Thanks - I'm planning on using the straight one. I've already cleaned it all up and will be going with the quick shift kit as well. I'll make sure I get a metal one.
Might have to shorten the shifter a little though, it darn near hits my dashboard.
Shifter
Postby the 'Maniac » 06 Tue May, 2008 11:08 am
I will definately need to shorten mine too!
the 'Maniac
