Rear Torsion Bars
Rear Torsion Bars
Postby Epimetheus » 04 Wed Jun, 2008 8:18 pm
Anybody have any recommendations on what rear torsion bars to use? Since I have the custom chassis I have no starting point. I know that the spring rate increases with diameter and decreases with length. I just don't know where to start. I am building a road buggy so I want tight, stiff handling, but I also don't want to be beat to death on a bumpy road either (such as the city of Houston streets around my house - gotta love city financed road repairs).
I'm pretty much open to suggestions at this point.
Adam
Is it normal to have absorbed more voltage than most household appliances?
Epimetheus
Postby David O' » 04 Wed Jun, 2008 11:59 pm
The spring rate is stiffer with the shorter bars, as well as the diameter.
Postby Bryan Porter » 05 Thu Jun, 2008 8:40 am
I used a 26mm short bar in my buggy.
I lower the setting and used adjustable
spring plates to get ride and stance that
I wanted. It worked for me.
Postby blackthree4me » 05 Thu Jun, 2008 11:44 am
I also used the stock short bar lowered two notches on the out side
I you have to buy bars just check with sway away and the should be able to do all your calculations based on weight and ride heigts
