Thanks for all the advice and the links to read about putting a Corvair motor into my buggy. After reading everything I think that it is more then a little scary to go with a Corvair Motor. From what I cut & paste below it pretty much firms up my thoughts. I am better off going with a VW...Now I just have to figure out if I am going to go 1735, 1835, or a 2110. Like I have posted before I have a 1970 single port, but its kinda hard to build it to where I want it to be. (Any Advice?)
: Right now there are a few of us playing with Corvair power. I am not the most experienced with Corvair and just at the point of getting into my first motor. I have tried to do my homework. I may feel different after I get all the bugs out of my first Corvair buggy project, but as I tried to bring my learning curve up I reached a few early conclusions.
1) Corvair parts are more costly than VW. Usually three times as much, and sometimes up to ten times as expensive. A quality rebuild of 140 Corvair heads by a rebuilder competent on them can cost as much as the parts and machining to completely rebuild a stock VW engine.
2) Good experienced human tech advise on Corvair power is hard to come by.
3) There are so many aftermarket VW parts available that one can build a reliable VW HO motor for less than a competent rebuild on a Vair motor. VW power to weight ratio will be great. With properly tuned carbs the gas milage on VW should be 20% better too.
4) Corvairs that are reliably rebuilt seem to have good longevity and great power. But if something breaks when I am 500 miles from home I doubt I will be able to get a Vair back on the road quickly.
