Aftermarket Speedometer
Postby ElijahTurtle » 06 Sun Jul, 2008 6:17 pm
Hey does anyone know of an aftermarket speedometer setup that runs completely independent of the stock setup? I was looking at going with disc brakes on the front & I haven't found a brake kit that mentions the speedometer. Does it function with most of these aftermarket kits? Or will I need to find a "creative solution" if I upgrade?
ElijahTurtle
Postby David O' » 06 Sun Jul, 2008 6:22 pm
Disc brakes work the speedometer just like the drums do.
Postby Aquabuggy » 06 Sun Jul, 2008 6:58 pm
GPS works completely independent, the after market speedos still use a cable in the spindle to drive a pulse generator.
As David stated the disc set up should work the same as drums (cable goes through the spindle and is turned by the dust cap)
speedo
Postby Texasbuggys » 06 Sun Jul, 2008 9:55 pm
Hey Chris K, this is a good place for you to contribute a little Texasmanx club tech article on your setup as a lot of people would be intrested and you have come up with a very cool option that would benifit the buggy folks.
Postby ElijahTurtle » 06 Sun Jul, 2008 10:20 pm
OK that's good to know! I had thought about getting a handheld radar gun & modifying it to clok the speed under the car & at the same time kind of jack with all those folks that have radar detectors. :twisted: Yeah I know that's kind of sadistic 8-)
Noteven sure if a radar controlled speedo is legal LOL
ElijahTurtle
Postby David O' » 07 Mon Jul, 2008 11:52 am
:shock: ?????
