Wiring
Wiring
Postby Jack Duncan » 06 Mon Oct, 2008 9:35 pm
Does anyone have or know where I can get a wiring schematic for a 1970 Standard Bug written for dummies? Maybe I'll get one with my new Bandit body, but I need one I can read and understand. :oops: :?: JD
Postby Faron » 06 Mon Oct, 2008 9:55 pm
I have seen a bunch of talk about wiring on www.thesamba.com Go check it out!
Postby JD » 07 Tue Oct, 2008 6:45 am
JD
Postby jspbtown » 07 Tue Oct, 2008 9:06 am
Jack,
A bug diagram will only go so far...and may be slightly confusing. There are lots of postings at the Samba as previously indicated. I've used 8 circuit systems which are available on EBAY with good success. 12 circuit models are also available. They don't have everything, but they are an affordable starting point.
Remember, everything on the Buggy needs to be grounded. On a standard VW the grounds are picked up by the metal bodies on lots of circuits.
Here is my 8 circuit on my old Manx. It was fully functionable (horn, wipers, lights,etc) and had 2 circuits left over.
happy to answer any questions you have.
Hey Jack
Postby Texasbuggys » 07 Tue Oct, 2008 12:15 pm
Post up some pics of your Bandit project!
Postby Ken » 13 Mon Oct, 2008 12:34 pm
Here is one I refer to from time to time.
Postby Peter » 09 Tue Dec, 2008 1:15 pm
Hello...
If you go here... www.manxmaniac.co.uk
and then to "Wiring and stuff", i have wiring diagram, it may help,
but i am not sure what you will need.
Regards
Peter
Or the the link below...........
Peter
