Fuel Pump
Fuel Pump
Postby Jack Duncan » 25 Sat Oct, 2008 11:04 pm
I need to know how dependable the little rectangular 4 psi fuel pump is. It is made in China and distributed be Empi. I bought one, but for some reason I don't trust it. I think I would prefer the vane type that puts out 6 psi used with a pressure regulator. I just don't want to be stranded in the middle of nowhere with pump problems. :?:
Postby GregR » 26 Sun Oct, 2008 7:51 am
I've always done very well with the stock pump. Even had to add a second gasket under it to lower the pressure...my kads didn't like it with only 1 gasket. Runs like a champ and has never let me down.
Postby Jack Duncan » 26 Sun Oct, 2008 11:06 pm
Thanks GregR but I am running dual Weber 44's. I've been told I have to run an electic pump. This was a turnkey engine and the mechanical pump opening is blocked off. :?
Postby Aquabuggy » 27 Mon Oct, 2008 8:53 am
Jack, Im running this pump on my green buggy with duel Dells also had one on my aqua buggy with a single Weber, no problems yet!
http://www.pacificcustoms.com/mm5/merch ... ange_high=
Mine is mounted in the rear but have been told it should be mounted in the front near the tank.
Postby Jack Duncan » 27 Mon Oct, 2008 10:36 am
Thanks Chris! Your pump is just like the one I bought, but mine is from China. The price was $23, so at that price I could carry a spare. I also have a Holley vane type from an old project. It stalled on me once,so I didn't trust it anymore.
Postby David O' » 28 Tue Oct, 2008 7:17 pm
Put the pump on and run it.....but at the same time a stock pump will pull duel 44's.
Electric pumps work or they don't, usually it is the wiring and not the pump.
