My question pertains to the indicator light that excites the alternator. (It doesn't excite me that much.) Does the light have to be installed in the circuit that goes to the alternator or can it be anywhere as a draw on the 12v system? My guess is that it is installed in the wire to the alternator.
Someone give me an answer please.
Here is another really cool VW wire diagram. I think this guy posted on this site somewhere, but couldn't find it. But I saved the link. Hope this helps.
I agree 100%. I use the turn signal lamp in my speedometer. Comes on when main power key is on and off when alternator begins charging. The lamp is then available for turn signal use.
Bryan Porter wrote:Ken you want it where you can see it as it will tell you if you lose a alt. belt and that could save you a engine.
