jspbtown wrote:I too have used the dune buggy shop harness on two cars so far. I get mine off EBAY though.
I like the way it works. I add some relays for my personal application (wipers, headlights, horn and flashers). I also make one modification as when you are done with the basic wiring you generally have two constant hot circuits left over. The mod I do makes it one constant and one keyed.
You still need lots of wire for the grounds. I run the grounds to a terminal strip which I think makes chasing ground gremlins alot easier. You also need alot of wire for most of the circuits. For an example the headlight wire is only about 6" long.
I also use the terminal strips for headlights and blinkers.
CoryN wrote:Cool that's what I got. I was just a little nervous they seemed a little lightweight
jspbtown wrote:Another relay if for the wipers. I bring power from the wiper fuse to the 30 tab on the relay. I ground the 85 tab, bring power from my switch to the 86 tab, bring power to the low speed tab on the wiper motor from the 87 tab, and run a wire from the 87a tab on the relay to the auto park on the wiper motor. With this set up you only have one speed, it will auto park, and I get to use a simple toggle switch which I like because you can use the same style switch for everything.
