Disc brake conversion
Postby fullup12 » 09 Sun Aug, 2009 10:31 am
Has anyone had problems with caliper and rotor lining up on after market kits? My calipers are too close to the outside of the rotors.This is a spindle and brake kit so you would think it should be a no brainer. My inside bearings are seated against the spindle correctly(rotor and caliper are stock type). Anyone have any ideas?
fullup12
Postby Tom Kathleen » 09 Sun Aug, 2009 11:59 am
Can you use washers to shim the caliper in the right direction? Or, if you need to go the other way, remove material from the caliper or mounting area? Tom
Manxter #16 & FiberFab Buggy
Manx Club, CVA, SCCA & RBC
Tom Kathleen
Postby fullup12 » 09 Sun Aug, 2009 12:10 pm
Shims would take them the wrong way. I probably will have to remove some metal to center them. Has anyone else had this problem?
fullup12
Postby BrianB » 09 Sun Aug, 2009 12:29 pm
What kit did you buy? I am about to buy a king and link type conversion with the drop spindles and it would be good to what brand you are having issues with. Did you use new Bearings? How much more room do you need? Good luck.
disc
Postby mike cook » 09 Sun Aug, 2009 1:42 pm
I had empi on my last buggy I had to put washer on fronts to center them same with rears but was still happy with them using them on the buggy I'm building now
mike cook
Postby Jerry » 05 Thu Nov, 2009 11:46 am
Same here, I had EMPI disck brake kit. I only had to add an extra set of washers on the rear to make em center...
My other email is Bacardibombillo3@gmail.com
Jerry
Postby Jack Duncan » 08 Sun Nov, 2009 10:15 pm
Speaking of wheel bearings, will drum beaings fit disc brake rotors? :?
