Remote Oil Filter installation???
Postby DannyT » 10 Mon Aug, 2009 9:25 pm
If I were to get this set up, what would I need to do to install it correctly?
I am thinking that I would need to remove the stock oil cooler and put an aftermarket one inline between the filter and the cooler adapter. Would I have to do anything to the oil pump end or do I just have to swap out the covers?
DannyT
Postby BrianB » 11 Tue Aug, 2009 4:46 am
Nothing like the factory cooling setup. I dont think there is a good place to mount the cooler on the buggy without it sticking out like a sore thumb. Why not go with a Berg Porsche fan?$$$$$$$$$$$$$
Oil filter
Postby Hawk » 11 Tue Aug, 2009 6:11 am
Hello, That pic is of 2 diff types of systems, Don't use them together. You will also need a cooler with fan and there should be room under the back seat.
hawk, decker
Hawk
Postby DannyT » 11 Tue Aug, 2009 6:55 am
Thanks guys, should have clarified.....this is a thought for my rail,not the wifes glass buggy. I am just looking at a remote filter setup, cant use the all in one setup, I have a bar in the way. And thought the remote cooler would help a little in the blistering heat around here.
DannyT
Postby BrianB » 11 Tue Aug, 2009 7:25 am
DannyT wrote: And thought the remote cooler would help a little in the blistering heat around here.
C'mon it not that HOT :twisted:
cooler
Postby cobra!tx » 13 Thu Aug, 2009 12:15 pm
this is my set up-you need to add an oil cooler in line -but the pump and case adapters are there along with the filter-I had it on a sandrail and am not using it on my manx
cobra!tx
