stering damper
stering damper
Postby matter396 » 21 Mon Sep, 2009 2:10 pm
thinking about a steering damper and I know one end goes through the hole in the tie rod, but where does the other end go. keep in mind I had a custom beam built, is there a bracket or do I need to weld on a stud?
Get out and Drive,
Mike
matter396
Postby jspbtown » 21 Mon Sep, 2009 2:40 pm
Welded bracket on the beam:
Postby Bryan Porter » 21 Mon Sep, 2009 3:34 pm
don't need it car is to light .
Postby tx_1987_gta » 21 Mon Sep, 2009 5:44 pm
I will be using one on mine... Is there anyplace out there to get a chrome dampner?
Thanks Joe
1981 Turbo Trans Am
1987 Trans Am GTA " Magic "
tx_1987_gta
weight
Postby matter396 » 21 Mon Sep, 2009 6:47 pm
unfortunately i don't think this car of mine will be to light. It is an on and offroad midtravel car. lots of steel in the front end and 30in tires, its big. pics to come after a bit. the bracket that goes on the beam, thats the part I don't have....can i get one somewhere or a clamp on style?
Get out and Drive,
Mike
matter396
Postby Aquabuggy » 21 Mon Sep, 2009 7:50 pm
Mike are ya planning to run a stock damper or something bigger?
I'm running the stocker on mine and it's working well with the 235x75x15's but I did add a little extra caster to my front end. Anyway if your going with a stocker just cut a bracket off an old beam that's what I did, I may even have an extra beam with bracket laying around if ya cant find one.
bracket....
Postby matter396 » 21 Mon Sep, 2009 8:02 pm
if you have one that would be great....I am planning on running a stocker and since I didn't start with a donor I don't have an old beam to get it from. I would greatly appreciate it.
Get out and Drive,
Mike
matter396
Postby Bryan Porter » 22 Tue Sep, 2009 8:58 am
Mike is your car at your house yet I would like to come by and see it.
not yet
Postby matter396 » 22 Tue Sep, 2009 9:14 am
not yet, still at bobby's but hopefully real soon!!! Down to just about the cage, lots of changes and more custom than we thought
Get out and Drive,
Mike
matter396
Postby Aquabuggy » 22 Tue Sep, 2009 7:46 pm
Mike I didn't get a chance to look but I'm almost certain I have an extra beam with a bracket. If its OK with Bobby Ill just drop it by his place. Id like to take a look at your buggy anyway.
damper....
Postby matter396 » 22 Tue Sep, 2009 10:37 pm
Thanks so much, I really appreciate it. I am sure he won't care. Let me know what you think!!!
Get out and Drive,
Mike
matter396
