Emergency Brake
Emergency Brake
Postby bobby hinman » 23 Wed Sep, 2009 5:32 pm
On the buggy I am fixing up the previous owner installed rear disk brakes. He took the line off the master cylinder going to rear brakes and put a push/pull valve in place of the emergency brake. I believe you hold down the brakes and pull up the valve to lock the rear brakes. The problem is the valve doesn't move and must be froze up. I am not real happy with the look of the valve. The orginal lever mounting bracket is still on the tunnel. Any suggestion for Emergency Brakes.
bobby hinman
Postby tx_1987_gta » 23 Wed Sep, 2009 5:34 pm
So basically its a line lock?
Thanks Joe
1981 Turbo Trans Am
1987 Trans Am GTA " Magic "
tx_1987_gta
Postby jspbtown » 23 Wed Sep, 2009 5:40 pm
Line locks are not always legal for street use. I can't speak for Texas, but you should check it out if it is going to be a street buggy. many states require a "separate mechanical" device.
If the rear calipers don't have the e-brake option on them, and you want to go mechanical, then you need two new calipers, two e-brake cables, and a new e-brake handle.
Postby DannyT » 23 Wed Sep, 2009 11:10 pm
Line locks are NOT legal for emergency brakes in Texas. I had to install e-brakes on my rail to pass inspection and was told at the pre inspection that it would have to be a mechanical brake and the line lock would not pass.
DannyT
Postby bobby hinman » 24 Thu Sep, 2009 5:31 am
How would I know the difference between a caliper that is E-brake equiped and one that is not ?
bobby hinman
Postby jspbtown » 24 Thu Sep, 2009 8:09 am
There should be a lever on the caliper. Post a pic if you can.
Postby bobby hinman » 26 Sat Sep, 2009 5:39 am
Did not find the e-brake lever on the old caliper. Can you buy just the caliper with e-brake?
bobby hinman
Postby jspbtown » 26 Sat Sep, 2009 9:54 am
Postby bobby hinman » 26 Sat Sep, 2009 2:40 pm
Thanks going to make sure that the e brake cable tubes are there. I was told that there are tubes that the cables go in that run up to the the lever. I am going to have to buy cables and lever also.
bobby hinman
Postby bobby hinman » 28 Mon Sep, 2009 9:11 pm
I can only find one tube under the emergency brake lever for a cable. Does each rear wheel cable come to the lever?
bobby hinman
Postby jspbtown » 29 Tue Sep, 2009 7:57 am
Yes, each cable should have one tune. You can see where the cables exit in this picture:
On the right of the picture (left side of the car) you can see a cable exiting near the rear frame horn and going to the backing plate. That is where they should exit. Do you have both exit points on your chassis?
If you have only one tune (be very sure first), then you MAY be able to get away with just one e-brake caliper. My thought is that they usually test the ebrake and one may be enough to hold the vehicle for the test.
of course I am open to alternative opinions.
Postby bobby hinman » 29 Tue Sep, 2009 3:24 pm
I live in Georgia and they don't do inspections and I already have the buggy titled and a tag. I want the ebrake for my safety. I will check the exit points on the frame. Thanks again for all the information
bobby hinman
Users browsing this forum: No registered users and 47 guests
