Fred wrote:I had the exact same problem on my buggy,nosecone of the tranny moved up and down and it slammed around in 1st gear take off. I tightened up the front trans mount and it worked perfectly-And- it was free, I'd definitely try that 1st. JMO, Fred
Fred wrote:I have the bowden tube, I didn't know it would work with out it!! If its not jumping out of gear tightening the trans mounts will probably fix it. Before I found the loose mount I thought there was something seriously wrong with the car. When I let the clutch out it would bang hard and if I idled in 1st it would rock and bang when i gave or let off the gas, Sound familiar?
