Tire sizes to keep speedo accurate?
Postby mwh986 » 05 Mon Jul, 2010 10:50 am
Found a great deal on some chrome 15" rims, but am peplexed aout the best tire size.
The rims are 15 x 8, so a wider tire should fit well, just don't know the "profile" % measurement to keep the the speedo acurate.
I'm thinking about a 265/60 15. In measuring the OEM VW tire it is 25" in diameter, so I need to keep the new one the same.......................correct?
What are others running out there?
Mark
1967 "Silver Sparkle Beetle"
Buggy Project in a Box
Beautiful San Antinio, Texas
mwh986
Re: Tire sizes to keep speedo accurate?
Postby BrianB » 05 Mon Jul, 2010 11:09 am
Why are you worried about the speedo? Just put the best looking tires that meet the look you want and then measure your accuracy later. 9 times out of ten you'll just be doing the same speed as everyone else anyway.
Postby mwh986 » 05 Mon Jul, 2010 11:32 am
Thanks Brian,
Just makes sense to me to match the tire with the speedo while I have the option.
Easier now than later, then it becomes a significant $$ issue. Besides the look is negotable to some degree.
What size tires are you running?
Mark
mwh986
Postby KIM-P » 05 Mon Jul, 2010 12:30 pm
Give your favorite tire shop a call they can give you all the sizes that are 15"ID x 25"OD. Thats what I did.
Postby mwh986 » 05 Mon Jul, 2010 6:38 pm
That's too easy..............
Mark
mwh986
Postby Bill K » 05 Mon Jul, 2010 8:44 pm
There's a shop in Houston that can put an in-line calibration device that will correct your speedo for the different tire size. They did mine and it turned out amazingly close. Cost was a bit under a $100 if I recall.
Postby jspbtown » 06 Tue Jul, 2010 8:07 am
Go to www.Tirerack.com
They have the specs for every tire they sell.
Your saying a 265/60/15....on the front? The front is the only tire that matters when using a stock speedo. The rears are irrelevant.
Postby Don » 06 Tue Jul, 2010 11:29 am
Tire size calculator including how much your speedo will be off:
http://www.miata.net/garage/tirecalc.html
Postby BrianB » 06 Tue Jul, 2010 12:12 pm
Thats right! I cant believe I did not catch that as well. The speedo runs off the front driver wheel.
Postby Jack Duncan » 06 Tue Jul, 2010 5:37 pm
My front tire is 185x60x14. It's diameter is 25", although I run an electric speedometer which is adjustable. My rear tire is 295x50x15. Speedo is perfect after adjustment. The cable turns a pulse generator sending a signal to the instrument. It's made by VDO. :D
