Just replaced front drum brakes with disc kit. Due to a brake pull with drum. Put kit in and bleed system got a good hard pedal. Problem is the same, still have a right front pull and wheel lock up. Replaced both front hose with rubber.
I was also disappointed in the braking, was expecting a big different, not much of an improvement.
My thoughts are the master cylinder or the hard lines coming out of the master cylinder.
Any thoughts or suggestions would be greatly appreicated.
HRW
