Monitoring Engine Temp?
Postby mwh986 » 17 Wed Aug, 2011 10:40 am
Is there a prefered method to monitor engine temp? I see two options viable, oil temperature gauge or cylinder temperature gauge.
What do most folks use, and which is a more accurate picture of engine health?
Mark
1967 "Silver Sparkle Beetle"
Buggy Project in a Box
Beautiful San Antinio, Texas
mwh986
Re: Monitoring Engine Temp?
Postby Bryan Porter » 17 Wed Aug, 2011 3:34 pm
Oil temp.
Postby mwh986 » 17 Wed Aug, 2011 10:58 pm
Bryan,
Thanks for the quick response.
If I install a "T" where the current oil pressure sender to share with the oil temp sender, does this indicate accurate temp?
Or is there another location on a 1500cc single port engine?
Much thanks!
Mark
mwh986
Postby Bryan Porter » 18 Thu Aug, 2011 8:05 am
best place is in the oil sump but you need to drill and tap a hole.
next is a dip stick with a temp sender.
I don't run one it gives me to much to worry about.
