Wide Ball Joint Front End
Postby Ken » 28 Tue Feb, 2012 3:16 pm
I would like to get a wider than stock front end on my rail and stop my tires from rubbing.
I find narrowed beams all over the place, but all the widened FE's I find say "for link pin".
What am I not understanding? Point me to an online source if you can, please.
Something with some lift adjustment would be great.
Re: Wide Ball Joint Front End
Postby CoryN » 28 Tue Feb, 2012 3:20 pm
Probably rare as hens teeth
Typically wide beams are for off road, and the Link Pin is always recommended for off road over the ball joint. Probably going to be hard to find one.
Can you alter the frame to accept a Link beam instead?
Postby GregR » 28 Tue Feb, 2012 10:20 pm
Check with Doug at Custom Buggy Parts, one of our sponsors.He can build pretty much anything you want.
Postby Ken » 28 Tue Feb, 2012 11:00 pm
CoryN wrote:Can you alter the frame to accept a Link beam instead?
What all do i have to replace?
Can i keep my disc brakes?
I'll need to go look at a link pin setup.
anyone got a diagram or pics?
GregR wrote:Check with Doug at Custom Buggy Parts, one of our sponsors.He can build pretty much anything you want.
thanks Greg I will.
Postby Ken » 02 Mon Apr, 2012 9:33 am
6 inch widened with four adjusters set at stock to raised. Do to arrive today.
But a brake ghost might make it hard to make the Classic.
I'll start a separate thread on the brakes.
