Turn Signal Indicator
Postby RobertB » 31 Thu May, 2012 7:12 am
I want to hook up the turn signal indicator on my buggy, but I don't know where to connect the wire coming from the little light bulb in the speedometer to.
It has a two tab flasher. If I connect it to one of those tabs, then the green bulb is on solid all the time, until I turn, then it blinks, after the turn, it goes back to steady on.
Do I need a three tab flasher? Any suggestions?
Robert
RobertB
Re: Turn Signal Indicator
Postby Bryan Porter » 31 Thu May, 2012 9:41 am
I think you do it has to be separate from the signal light or all 4 will flash at the same time
Postby GregR » 31 Thu May, 2012 9:00 pm
I found this for a 3 prong flasher
Postby RobertB » 01 Fri Jun, 2012 7:50 am
That's exactly what I've been looking for! :D :D :D
Thanks a billion Greg,
. . . . . . . . . Bob
RobertB
