Oil Pump failure
Oil Pump failure
Postby starrfisherman » 07 Fri Jun, 2013 10:30 am
I had an odd thing happen yesterday when I changed the oil on my buggy. After draining the oil, cleaning the oil screen and changing the filter, I started the engine and had no oil pressure. Went back and checked everything and found nothing wrong. So, I pulled the oil pump off and found the gear was spinning on the shaft from the cam. What the heck caused this? So, I have a new oil pump on order and hope all goes well. Has anyone else run into anything like this?
Herb Fish
starrfisherman
Re: Oil Pump failure
Postby staggerwing » 07 Fri Jun, 2013 2:52 pm
Postby Ken » 13 Thu Jun, 2013 12:25 pm
So did you find what the problem was yet?
Postby starrfisherman » 13 Thu Jun, 2013 6:06 pm
I found a 6mm flat washer in the pump. I guess it got in between the gears and caused the main gear to spin on the shaft. I am now trying to figure out how this washer got past the screen and into the pump. I cleaned everything up and made sure there was nothing else in the oil passages. Installed a new oil pump and everything seems to be ok. Will now go out and drive the heck out of it.
Herb
starrfisherman
Postby johber41 » 13 Thu Jun, 2013 11:03 pm
Hey Herb, Had the same kind of thing happen to me where I found a square nut lodged into the head of the no.1 cylinder. I do not think that there is a square nut application anywhere on the engine, but, it was in there just the same! Scotty must have beamed the washer into your pump from the Enterprise!
