New floors
New floors
Postby Buzzfagan » 20 Wed Apr, 2016 9:01 pm
I am needing to fabricate new floors for my Manx buggy project and wanted to get some suggestions and ideas.
I was thinking of getting some type/thickness of metal and just cutting it to size and welding it in place. I am not sure how this will work or how to exactly do it or what to exactly use. Just have some ideas. I am not sure if it will look good or be noisy or any other bad consequences if this method.
I am open to any other ideas, and I think there has got to be some better ideas out there than mine somewhere. Please share your thoughts.
See photo below for what've am working with. It is a shortened chassis that already has some supports across the bottom from side to side.
Thanks for your help!
Re: New floors
Postby Bryan Porter » 21 Thu Apr, 2016 9:11 am
16 ga. steel plate works great
Re: New floors
Postby Buzzfagan » 21 Thu Apr, 2016 6:20 pm
If you were going to use steel diamond plate would you use 1/8, 3/16, or 1/4"?
Re: New floors
Postby BrianB » 21 Thu Apr, 2016 8:38 pm
Buzzfagan wrote:If you were going to use steel diamond plate would you use 1/8, 3/16, or 1/4"?
1/8"
Re: New floors
Postby Bill K » 22 Fri Apr, 2016 11:19 pm
You are on the right track. I shortened my pans and won't ever do that again.
