Install Clutch Cable
Postby Bill K » 11 Tue Jun, 2019 9:01 pm
Who knows the trick for keeping the cable on the clutch pedal hook when reinstalling the pedal assembly?
I get it on the hook and even used zip ties on it, but when I put the pedal assembly in place the cable keeps coming off the hook.
Re: Install Clutch Cable
Postby KIM-P » 07 Fri Oct, 2022 11:26 am
I have drilled 2 small holes in the hook and ran a piece of safety wire across the gap to capture the cable end.
