Super Beetle as a Donor?
Postby staggerwing » 03 Mon Jul, 2006 1:19 pm
This is my first shot at building a buggy. I have a 73 Super Beetle I can use as a donor. The question I have is "is the front bulkhead of the Super Beetle chassis made the same as a standard pan so that I can bolt up a king pin or ball joint front end?
Postby GregR » 03 Mon Jul, 2006 1:42 pm
No, they're very different. The Super Beetle uses McPherson struts that tie the front end to the body.
It is possible though to weld a Type 1 (beam) frame head in place of the Super's. Measure once or 2 or 3 times, cut, weld once :D
