Hey, just a thought and a question to you folks that already have your rides on the road...
how many of you re-used your stock VW hardware?
How many of you upgraded to grade 8 and 10, and on what components?
Not including the engine, what bolts recieved a bit of loctite?
On my ride, the majority are Grade 8, and if not load bearing, they recieved a grade 5 nut... some of the 'exotic' bolts, i.e. steering box bolts, shock bolts, etc. were just cleaned factory parts..
Do you prefer a longer bolt with a lock washer and nut, or a shorter one with a nylock?
Just curious on what's holding your rides together!
