Full flow oil filter?
Postby Aquabuggy » 22 Wed Nov, 2006 3:45 pm
Does anyone (David O.) know which line goes to the filter inlet and outlet? There is one line that comes off the block and one comming off the oil pump.
Postby Aquabuggy » 22 Wed Nov, 2006 3:47 pm
Also what type oil filter do these things use?
Postby David O' » 22 Wed Nov, 2006 4:32 pm
The line from the pump housing goes to the inlet of the oil filter and the other one goes from the outlet side of the oil filter to the fitting in the block, filter is the same as the rabbit. (or something equal to it)
Postby Aquabuggy » 22 Wed Nov, 2006 6:04 pm
Thanks David O. I don't know what we would do without ya.
Hope ya have a Happy Thanksgiving
Postby Mike & Mel » 24 Fri Nov, 2006 12:59 pm
I use a Fram HP-1. It resists the urge to blow out under the high pressure put out by a VW motor.
Mike & Mel
Manx Club #2265
Texas Manx Club
One of T.O.P.s
Joe Poty Sand Rover
Mike & Mel
