Cylinder-to-case sealant
Postby Classic Manx 71 » 02 Tue Jan, 2007 12:41 pm
What do my fellow members recommend for cylinder-to-case sealant on the VW engine? I have heard that RTV silicone is good but will ruin bearings if any gets in the oil distribution system. Is there something better? Thanks.
Classic Manx 71
Postby David O' » 02 Tue Jan, 2007 5:53 pm
If the cylinders are stock, use the paper gasket and aviation permatex, if not, orange silicone....but only at the base of the cylinders.....not the case.
This is done by putting a small bead of the stuff around the lip at the base of the cylinder and pushing the cylinder down to the case.
