How do you identify between type 1,2, and 3
Postby tjheller » 27 Sat Jan, 2007 11:52 pm
I've got a '66 with a shortened pan. When looking up parts I see that a '66 falls into all type categories. What's the difference?...and should it matter since it's a fiberglass buggy? Also, is there a source for pre-shortened cables etc. to take into account the shortened pan? Thanks.
tjheller
Postby tjheller » 27 Sat Jan, 2007 11:54 pm
Wrong forum, sorry. Maybe an admin can move it to tech.
tjheller
Postby David O' » 28 Sun Jan, 2007 4:03 pm
There is no source for preshortened cables, due to the difference of different types of sproceedures used in the shortening proccess. The only knowledge you need to know about the 66 is, whether or not it is a type 1 or Ghia model, with the difference eing the shapeof thepan sections. The type 2 is the bus models, and the type three will have a completely different front beam attached to it!
Postby GregR » 28 Sun Jan, 2007 5:52 pm
custom shortened cables can be had from http://www.push-pull.com/ Just give them your measurements and around $30 if memory serves.... :D
Postby tjheller » 28 Sun Jan, 2007 8:27 pm
Thanks for the info....type 1 it is.
tjheller
