by tjheller » 05 Mon Feb, 2007 11:01 pm
What is the round thingy on the carb called that holds the cable in place? Is it available by itself? I see that I can buy an E-brake shortening kit, but what about the throttle? I just got a new master cylinder today and it's different than the one I pulled off. The new one has an outlet on the very front, then three more at 90, 45, and 135 degrees. Any idea of what hole goes where? Does the main line (brake line) to the rear run on the port side of the "tunnel"? Thanks. I'm not new to working on stuff,...just VW's.
