Buggy won't idle after warming up
Postby Rick Leddon » 05 Mon Mar, 2007 9:04 pm
I put a new carb on and after the choke opens up all the way, the engine won't idle. I don't think I have the idle too low. This is a rebuilt carb I just installed. The engine ran fine before installing the new carb. Any advise.
Rick Leddon
Postby Tom Kathleen » 05 Mon Mar, 2007 9:49 pm
Vacuum leak? Is it a 34 PCIT? If so, the idle shut off selenoid may not be working. These are just the "easy" reasons for no idle. TOM
Tom Kathleen
Postby David O' » 05 Mon Mar, 2007 11:41 pm
Check the setting on the side of the carb and see if they are right, or you have a possible intake manifold leak.
